Structural engineer issues… help!
We are now well into our build and I’m having some issues with the structural engineer.
I have some questions around locations of beams and possible alternatives and I cannot get him to respond to emails or phone.  He was recommended by my architect but has apparently taken offence to my questions and now won’t respond at all.  We don’t have final calculations and some of what was in the initial calculations simply doesn’t make sense!
Help!  Do I bite the bullet and go for a second opinion (probably at a reasonable cost).  If so who, any recommendations??
1 minute ago, joe90 said:
I hope you have not paid him? You have no choice but to find another S.E.
Unfortunately yes paid.  Really not happy but at a loss as what to do if he won’t respond really.
We’re now at the point where some steels are on site and up so I need some questions answered asap…
Post drawing extracts and your main questions. We can't do the work itself but might be able to suggest whether it is worth getting that second opinion.
Although with steel on site, there is likely to be a cost for changes.
6 hours ago, Temp said:
How long has he been AWOL?  He's not just on holiday or down with Covid?
It’s been a month… plus architect has said he’s talking to him on other jobs.  He’s trying to talk to him about mine also and getting no luck.
Ok… one of my main questions is B14 and B15.  Where are they?  They’re labelled as in the gf ceiling but also labelled on the roof plan as ‘under’.  Also what is their purpose?  They are below a stud wall, if it’s support for that then can we not double joist to allow for MVHR etc.?
Also Trimmers shown.  I’m assuming they’re to support the ridges but it’s a hipped roof so they can’t be at ridge height else they’ll be sticking out the side.  Also ceilings will be sloped as eaves height is quite low so they’d need to be below that?
7 minutes ago, Miek said:
I'm not an expert. But from the notes B14 & B15 are '203 VC 71'
So steel columns
That might make more sense but a lot are labelled as UC and they’re definitely not. B5 etc.
Below is the connection detail which also indicates it’s in the gf ceiling…
Looks like he is speccing a channel which would be RSC never seen VC. Channel would make sense but a 254 is a biiiig channel.
16mm end plates? Are you building a nuclear bunker?
I would be getting a new SE and probably save you a fortune in steel fab and erection costs
Edited by markc
i suspected over engineering as much.  So far we’ve had a slab with two layers of 10mm mesh and B5 has changed to a 451 UB 97.  Fabricators struggled to locate one so short as they usually come in 30m length for railway bridges!!
 Oh and 20mm plates and stiffeners everywhere.  Over 5m and 300kg of 20mm plate in the one beam and connections.
  • Confused 1
@matthyde83 you need a new engineer sharpish !!!
Lintel notes “all lintels require 3 courses Class B” is ridiculous, as is the use of bolted 150/50 next to Velux windows and 400mm centres on sloping roof sections. He should have upped the sizes to the next size and you can then at least insulate properly too.
I don’t want to know how much you have paid but this is serious overkill on engineering….!!
It might be they've accidentally used B14 & B15 references twice.
From what I can see, at GF B14 is a catnic lintel and B15 is a steel beam spanning from C1 to masonry wall.
The next B14 and B15 steels are in the ceiling at roof level. They're probably there because the ceiling joists can't span and they wanted the ceiling joists to align through in the same direction as the rafters.
I can't quite work out the roof structure but it might have been subcontracted to a roofer. The additional beams may help support there.
3 courses of engineering brick under lintels is a bit OTT but no reason not to in a new build. If the windows are ~2m+ wide then sensible enough.
