Hot Wire Cutter for EPS
Tiny
Hi Folks,
Has anyone got a hot wire cutter that they no longer require, or are about to come to the end of using? We are about to order the EPS to EWI the outside of our build and it would be a lot better quality of job and less mess with a hot wire cutter. Happy to buy a used one.
You'll be there for years. Great for chasing for conduits but that's it. A slightly blunt handsaw is perfect. Doesn't matter if it's rough cuts as any gaps will be foamed, the lot will be rasped and covered over forever!
