VAT abolished on solar panels insulation and heat pumps
Radian
I have not read the article, but I heard the speech live and it mentioned "installed heat pumps" and same for solar panels, so does this only men the 0% is supply and fit, or will you be able to buy one to DIY install at 0% VAT?
Call me cynical but I expect this to require installation by an approved contractor or agency....again.
Or a lot of paperwork and applications.
But I agree with the principle. No VAT on insulation would be  a very efficient fix for the reduction in energy use, and the nation would get a quick return.
The way it is worded it sounds like it's gli g from 5% to 0.  In which case it will only be on installs?
My understanding is that the materials need to make up for no more than 60% of the install cost to qualify for the 5% rate.  Hence why we pay 20% to buy them for DIY?
Edited by BMcN
AIUI as from 1st April 2022 the 60% rule no longer applies.
10 minutes ago, joe90 said:
This might make my DIY PV instal a Goer, just need confirmation of zero VAT on the kit itself.
That's a good point. The majority of the cost of my install was the mounting kit and inverter. Panels £2k, everything else £3k.
5 minutes ago, ProDave said:
Sorry to be the bearer of bad news, but as I feared the 0% only applies to supply and fit.  Sales of equipment only will still be 20% VAT
https://www.bimblesolar.com/budget22
More jobs for the boys. They don't really want us to install green energy products.
Don't shoot the messenger.
Does seem daft. If the old 60% rule no longer applies then might not a builder be contracted to supply the materials for a DIY install and charge a nominal sum for 'installation'?
I have just had a look at a site for panels, and they claim it is on full systems only?!?
So if I wanted to top up with 4-5 panels, I won't get the 5% break, however, I think all the companies will just bump up their price 5% and leave it as was claiming "rising costs" prices never come down!
If you can find such a VAT registered person to do that, it would probably work, to justify that he would surely have to do some "install" work, perhaps fix the rails to your roof and let you do the rest.
but unless it is someone you know, I doubt many would be wanting to put a substantial sum through their books with all the VAT paperwork for little income.
What I was thinking is that there may be some flexibility for self-builders who contract out certain elements of their builds. A good relationship with a builder might lead to some sort of arrangement that is of some financial benefit to both parties. I'm trying (and failing) to get my head around the reason for the materials themselves not to be tempoarily zero rated like children's clothes, books and newspapers.
It is obviously NOT about maximising the amount of green energy products installed but all about prolonging schemes like MCS etc and trying to make it so DIY is impossible.
This keeps on rearing its ugly head. Perhaps something like the Good Law Project should get involved in investigating the various schemes and their funding.
I refer you to the answer I gave earlier.
So they will again spend Millions of our money on administering the schemes, and hardly anything in grants.
It can no longer be ignorance and must be cynical (followed by a photo op of putting petrol into a borrowed small car)
3 hours ago, joe90 said:
If loft insulation was zero so many more people would install it IMO.
I see it also includes draught excluding strips -- who the ?*!# is going to hire a trade to install those?
Yes and what's more, the supply and fit must be a standalone job, not part of a bigger job such as renewing a roof (as maybe required to install solar) or lining a building with airtight membrane. So doing a serious retrofit like to EnerPhit standard will still all be 20% VAT if instructed through a single main contractor, or if done DIY. The only way to get the savings is to pay lots of individual trades separately and risk the work not joining up, which is especially bad if EWI is not joined into other improvement work correctly (for example) allowing damp in.
Shame, it would have saved us about £8000 in vat if this was workable.
5 minutes ago, saveasteading said:
anybody got the daily mail take on it?
you asked. https://www.dailymail.co.uk/news/article-10643903/Rishi-Sunak-says-thanks-Brexit-able-axe-VAT-solar-panels.html
"Conservative MP Anthony Browne said: 'As energy bills rise, it was welcome to see the Chancellor recognise the important role energy efficiency can play by cutting VAT on energy saving materials such as solar panels, insulation and heat pumps to 0%."
Nope, he has NOT cut the VAT on "materials" he has cut the VAT on supply and fit.
  • Sad 1
