Battery storage, could be old news
JohnMo
Battery storage may have an alternative technology on its way - the flywheel.
https://www.pv-magazine.com/2022/02/24/french-flywheel-storage-system-specialist-secures-e10-million-investment/
Funny thing I did a a project paper on this subject 30 years ago.
There was even a Le Mans race car with one installed in the early 90s and trams have had them installed for energy recovery and storage.  Run a flywheel on magnetic bearings and in a vacuum, nearly no standing losses.  Use a magnetic clutch to engage a motor/generator for power output and power input.
It's not rocket science as they say, just some kenetic energy.
I looked into it as well.
The energy density is not that great, even if the power density is good.
And the thought of having a washing machine sized bit of kit with a flywheel, rotating at 20,000 RPM, is a little worrying.
Williams Engineering used one in their cars in 2009, when KERS first came along.  They sold it to GKN back in 2014.
Think there may be a system on Eigg, not sure if it is running.
2 minutes ago, JohnMo said:
Centrifugal gas compressors routinely run at that or greater speeds without issue
Not in the cupboard under yours stairs though.
We need to pay for a certificate to have a DHW cylinder running at 3 bar, just imaging what a fast spinning device with 5 kWh of energy will need.
It is already used for grid balancing, if you go to WPD substation near Redruth, you can hear them humming sometimes.
https://botlanta.org/converters/dale-calc/flywheel.html
