Connecting 32 mm main to 10 mm cold water pipe
Omi
Hello,
How would I go about connecting a 32 mm mdpe main to the 10 mm pipework on a caravan?
I can see reducers to go from 32 mm to 25 mm mdpe and pipe fittings for 15 mm to 10 mm but can't figure out how to go from 25 mm to 15 mm?
14 minutes ago, Omi said:
Can it also be used with PEX/PB?
Yes as long as you use an insert https://www.screwfix.com/p/jg-speedfit-superseal-plastic-push-fit-pipe-inserts-15mm-10-pack/69329?tc=SB6&ds_kid=92700055281954514&ds_rl=1249404&gclid=EAIaIQobChMIm7fnkcPa9QIVibbtCh2QHQ4pEAQYAiABEgKVIPD_BwE&gclsrc=aw.ds always use these with plastic pushfit plastic pipe
edit, no such thing as a stupid question, stupid is not asking ?
Edited by joe90
