Internal Insulation
richo106
Hi all
With our build in its planning stage just trying to sort some finer details.
Our existing bungalow only has a 70-80mm cavity (blown insulation in it I believe) we are going to insulate internally
what would people use to insulate inside?
50mm celotex or 50mm rock wool?
what is the best method to install it? New metal stud inside? Battens?
All advice greatly welcomed as I am struggling for the best way to do this at the minute
Many Thanks
Edited by richo106
No studs, no air gaps, sheet material is best either composite or stuck together on site as it goes up. Composite is easiest and quickest but more expensive.
should start with a target U-value and go from there
i use fixing foam and the next day six insulation fixings  per sheet belted well in
Just had 75mm of PIR backed plasterboard put on my internal walls and it’s made an amazing difference, still a long way from perfect but it was a free government instal so not to be sneered at.  The house is very old traditional Scottish two up two down with stone walls air gap and wood panelling on the inside,  the installers used a both foam glue and screw fixings to to attach the sheets straight to the wood panelling and the plasterer came in a few weeks later and did a fine job covering up all obvious imperfections.  I am a fan of PIR over rockwool when space is a premium and you can control the detailing but rockwool is a lot more forgiving if detailing is going to be a problem.
4 hours ago, nod said:
Your best option if you can afford to loose a bit of internal room is Gpyliner with a 50 mil rock wool slab 10 mil off the walls
Thanks, this was my original thought with 50mm studs. How does rock wool compare to PIR in terms of insulation? Im guess rock wool a lot easier to use/install?
So fixed 50mm pir directly to the wall? Tape them together?
how would I attach the plasterboards? Sorry for the daft questions
May I ask how you got it via a free install?
25 minutes ago, nod said:
The ones that are pictured where put in for sound
While pir stats may look slightly better
The rock wool give a tighter fit Behind the gypliner and around the brackets
You could always dab insulated pb directly to the wall
Not as good as an air gap
but easy option
My ex partner lives in the house and claims family tax credits to top up the care work she does, just being on the register made her eligible and as I do not charge her rent I did not have to pay towards the upgrade.
but easy option
i should know this but why is the air gap so important @nod is it just to do with the reflective property of the PIR boards ?
@Cpd, no air gap increases the heat loss by conduction
A 25mm air gap without reflective surfaces has a thermal resistance of 0.18m2.K/W, an air gap with a low emissivity surface 0.44m2.K/W.  25mm  of PIR has a thermal resistance of 1.09m2.K/W and 25mm of EPS about 0.7m2.K/W.
pages 19/20 of attached PDF
BR443-October-2019_consult.pdf
