Cost for good quality double glazing
Ferdinand
Following on from January's Cost of triple glazing thread, is anyone willing to share the approx cost of their double glazing?
I will be receiving my quote for the Little Brown Bungalow replacement DG this week, and would welcome some comparisons. In theory I should be in a good place, because my DG man measures up and has it made half a mile down the road, and I can't see how that can be improved.
Cheers
Ferdinand
On 18/04/2017 at 09:28, PeterW said:
Drop a couple of sizes / glass specs on here and I'll see what mine comes out at ...
Will need to measure up. Will reply later today.
Ok @PeterW here you go. I need the following supplied and fitted.:Full details but an approx indication is fine.
White uPVC. Everything is grade A with chromes handles and high security (anti bump, anti snap) locks. 225mm or ideally 250mm sills.
Spec of unit is 4-20-4 float glass warm edge argon filled. I make the u value 1.4-1.5, so Ok for DG but not as good as is available.
Front door: 2.1m h x 1.5m w door (900) and flush upvc side panel (600) Door 2 light top half with mullion, raised panel below.
Back door: 2.1m h x 0.9m w door. Door identical to front door.
Picture window:  3m w x 1.3m h. 1:3:1 division into lights. One light opening.
Window: 1.2m h x 1.2m w. 1:1 division vertically. One light opening.
Window: 1.0m h x 1.2m w. 1:1 horizontal division. Bottom light opening.
Window: 0.9m m h x 1.2m w. 1:1 horizontal division. Top light opening.
Window: 1.2m h x 2.2m w. 3 lights. 1 light opening.
French doors.2.1m h x 1.8m w. Both doors opening.
There will be a certain amount of building work (eg French doors replacing window but no lintel needed), which I am excluding.
Ferdinand
Edited by Ferdinand
Dimensions included.
