Why aren't A2A ASHP more popular
RomyD
1 hour ago, puntloos said:
UVC? A google search says Ultraviolet - to clean air, desinfect?
Unvented cylinder.
This one is heating only though. Did you intend that?
No that was an accident. Didn't know that about split heat pumps re efficiency.
An update to my thinking:
Water FCUs are pretty lossy- you'd have to convert air to coolant to water to air. Also, because the temperature of the water going through a water FCU is low, the unit is less effective.
Coolant (R32) FCUs can be more effective and therefore probably quieter.
As such, I think I would currently pick two separate devices
A2A Multi-Split ASHP with ideally one FCU per major room.
Small A2W Split ASHP, probably from the same brand so the same team can install them. Drives hot water and UFH
I know it's doubling up on the devices but ha, some high capacity ASHPs have two fans anyway, so having two 1-fan devices almost doesn't make a difference, same trench for dual coolant lines etc etc. Hopefully this will not be *too* bad an additional cost in the greater scheme of things.
My big question: if a concealed ceiling FCU is "200mm", would it fit in a 240mm ceiling? You'd think, but for example this brochure:
https://www.daikin.co.uk/en_gb/products/fdxm-f9.html - says the device is 200mm high, but also "Compact dimensions, can easily be mounted in a ceiling void of only 240mm"
What gives? How much void do I need? (my current design is 210mm)
