19mm pipe with wire spiral inside
canalsiderenovation
I confess this is for our boat as we are fitting a whale gulper pump in our bathroom. We need some 19mm hose and we have been advised to use  the type with a wire spiral inside which won't collapse under the draw of the intake side of the pump
Similar to this:
https://www.midlandchandlers.co.uk/products/hose-suction-green-3-4-id-per-metre-ah-001
Does anyone know of anything like this I can get online (the chandler's isn't local).
Ta
