Outdoor brick socket?
ashthekid
Might be a bit of a challenge as usually the cover goes down over the plug and cable to give it water protection. If the face of the cover was flush how would the cable come out?
Edited by Marvin
15 hours ago, Onoff said:
Is this for external use or an internal brick feature?
Yes this is for external use but i don't like the bulky standard outdoor sockets that would stick right out on the brick wall surface.
@Roundtuit That makes a lot of sense, at least that would get rid of some that bulk. I don't mind them sticking out a little bit.
9 minutes ago, Nickfromwales said:
For the flash people out there, the Lewden offering could be in a box made from cement board and covered i sacrificial brick slips, which could be 'dismantled' if the socket ever failed.
And they say I complicate stuff! ?
3D print a plastic back box with no stub and a 20mm rear entry hole!
