Is there any benefit in having a floor finish in the storage space in a loft?
Adsibob
The chipboard floor has gone down in our loft conversion. There is an 5.5m2 area which has restricted height which we are going to use as a storage space. Is it worth putting something over the chipboard to protect it, or should I just leave it as bare chipboard. The only reason I can think of putting something down is that if the roof were ever to leak or if something spilled internally the chipboard would get wet. If I were to cover it with something, what's the cheapest thing to use? Linoleum?
If it is the waterproof type, then dampness is not an issue.
But your roof should not leak, and if it did it would pond on the lino and then run off.
Try without.
For a cheap fix, apply the cling film that is sold as floor protection during works.
NO NONSENSE HARD FLOOR PROTECTION ROLL 25M X 500MM (32544)
