Vapour control barrier in drylined walls?
WWilts
10 minutes ago, TonyT said:
Adhesive frame- do you mean dot and dab?
Yes, but frame and dab. So in addition to dots there will be a continuous frame of adhesive all around the perimeter of the plasterboard lining. Intended to reduce the amount of cold air that drops down into the room.
Does drylining allow any kind of membrane to be used as a continuous air barrier?
Edited by WWilts
Is it a new build? You can add a parge coat to the walls first. This is a very wet layer of plaster. So wet you can put it on yourself like a thick layer or slurry paint. A lot of members here have done that, myself included. The quality of the plasterboard doesn't matter as much then
1 minute ago, SteamyTea said:
Where is this air coming from, and is it bypassing any insulation?
Presumed leaky walls (outer brick, inner aircrete block, 10mm mortar 1:5). Despite concave tooled joints that are reasonably well filled. Cavity to have bonded EPS beads blown in.
If the cold, outside air, is getting past the beads in the cavity, this negates the point of insulation to a certain extent.
Are you going to render on the outside to improve this?
Some outside air might get in, or inside air might get out, if the wind gets very high outside. Presumably through minute gaps in the mortar and any air channels remaining in the bonded beads.
No render, facing brick outer leaf.
Parge coat will help. Could an airtight membrane be attached to the inner leaf internal surface, and then the parge coat placed on the airtight membrane? Suspect there will not be sufficient key to hold the parge coat to the membrane.
Edited by WWilts
pics of joints (external face of brickwork, internal face of blockwork).
Look ok to me, although an aluminium post is fixed to brick mortar each day for a line, and it leaves a small hole. Will ask for those holes to be sealed with mortar.
Trying to understand it all so that the generally co-operative and trustworthy builder can be pushed only where it is necessary.
Edited by WWilts
Forgot the membrane. It's not needed and you'll need to introduce battens if you want to use it on the walls. You have blockwork internally which is perfect for the parge coat I mentioned earlier. Go around with airtight tape and tape everything; around doors, windows, floor to wall, walls to airtight membrane in the ceiling, around all pipes and cables going from inside to outside. Then add the parge coat. This will give you a brilliant airtight home to Passive House standard and is something you can do yourself to save money if needed.
You do not need an airtight membrane to the walls but do for the ceiling.
3:1 sand:cement? Lime required? Any need for any other ingredients?
Given how messy it is, would it be ok to put the parge coat on before the penetrations by cables etc? And then rely on airtight tape to seal around the penetrations? Else the screed might have patches of slurry making the surface uneven.
