Window lifting equipment
gmarshall
Hi All
Our windows arrive shortly so I need to think about lifting them (fitting them ourselves- timber aluclad). We have a few large first floor units- largest is 2.3 m wide and weighs ~100 kg, and a couple of larger units downstairs - largest a 2.6 m triple glazed slider weighing in at 250 kg.
Does anyone have any recommendations of lifting kit to hire, or any other tips for that matter?
Telehandler and MRT4 vacuum sucker from GGR, you’ll need to have hired in equipment insurance or telehandler and slings. Important to understand distance from forks to glass and protecting the glass.
One wrong move and you’ve smashed the glass or dropped the unit.
If you have balls of steel, man power.
Edited by craig
I fitted all mine, big windows 125kg, big doors 250kg.
I paid for fitters on the door as i wanted  the extra warranty, the company wanted to charge for a spider crane and suction device, I told them we would supply extra labour to lift them.
When the fitters came they said even if I had of paid for the spider crane they would prefer to lift them manually, they said the Crain is only any good for second storey windows in the region of 200kg, any less they just pick them up.
4 lads with a large sucker each and our door was in. A170211D-D037-4769-A921-10E87F284E87.thumb.jpeg.554427cb8d916eedfd90f73169d8518c.jpeg
Windows lifted to this second level with a genie lift.
Just bare in mind, that health and safety requirements indicate that mechanical lifting should be used. "If" anything was to go wrong because the risk was not assessed correctly, it will result in the wrath of the HSE. That's why lifting equipment is recommended (installers usually prefer to manually lift, as it saves time and generally not that heavy) & self builds are generally not as strict as commercial.
Genie lifts are good but I'm not a fan of the restrictions they present. You need a solid flat ground externally to use them and you need to be very close to the building to utilise them. This is the same with glazing robots (even the offload versions) & why we prefer a telehandler & vacuum attachment.
Spider cranes are good, we tend to use them for curtain walling but generally you need to offload the windows and doors which are palletised & we need a telehandler for that anyway and a weeks hire for a telehandler & vacuum sucker is better than the stop/start and repositioning required with a spider crane (it's just slower).
2 hours ago, ProDave said:
Obviously took the sliding sash out to halve the weight to lift in one go
Sensible.
Having recently done my own windows, and mainly on my own, I'd would say it depends entirely on access and space around your house. With my installation it was such that I couldn't use any of the commonly available lifting equipment e.g. telehandler, spider crane, tracked lift, glazing robot, or a genie type lift (I hired one of these thinking it could work). I had to make my own lifts using Kwikstage scaffolding and an Elephant chain hoist using a hired in 4 pad suction lifter.
I used Hird for my equipment hire who were very easy to deal with and much cheaper than GGR who I found wanted to over-sell equipment (and operator) and were a bureaucratic nightmare for a self-builder!
Thanks all, really useful stuff. We are a refurb project, and whilst access is good at the front it's less good at the back (genie lift etc ok, telehandler definitely not!), So good to know smaller options have worked for some. Planning to tackle some of the smaller units first, then the bigger ones with easy access and the trickiest last.
Here's hoping for some reasonable weather for a few weeks!
  • 7 months later...
Resurrecting this thread.
My windows are mostly in and looking good.
But the builder is struggling with the largest window.
The windows are from Russell
We have a 3G slider that is 3.7x2.5m and weighs 467kg.
Original plan was to move it through the house into position on rollers. builder is concerned re safety of this and the amount of labour needed.
Current plan is to use a large crane to lift it over the house and lower it down into position. The crane company are uncertain if they have window lifters for the width of the quite deep frame.
Apparently the fitters normally deal with Velfac and would dismantle such a large window and then put it back together in place. Russell have told them that they cannot dismantle the window although I have not had this conversation with Russell. It would seem that if we could take the slider out and reduce the weight to <250kg then things would be a lot easier.
Very difficult to move the window round to the back of the house due to scaffolding and lack of flat ground.
Does anyone have any suggestions?
Rolling a half ton huge panel could be somewhat dangerous. I'd say you want plenty of rollers to avoid a point load occurring on the bottom of the unit.
They may not want it dismantled due to warranties perhaps, but if its done with care this would ( and will be ) my favoured route.
Let us know how you get on as I have an almost identical unit coming in the autumn .
You should be able to take the sliding sash off, reducing the weight by 50%, we normally use a one wheel bogey too transport through the house. Alternative option is using an Oscar 600 off road but you can only use the fixed pane for lifting. A telehandler with fork attachment and vacuum sucker is your best bet if you can navigate around the outside of the house.
Thanks Craig.
Just spoke to the builder. He says the plan is to attach suckers to the fixed pane and open the moving pane enough to get a strap around the frame.
I did ask the question as to whether the top of the frame can take the weight which he did agree he would have to check.
If you're using straps, you need to lift from the bottom and you don't need to open the door to do this. However, I do presume he means a lifting strap around the bottom for 2 men to assist with the lift.
Edited by craig
No, that was the question. He was thinking of opening the door enough to put a strap through under the top of the frame.
I pointed out that the top of the frame was probably not designed to take any weight.
I assume from what you say that you agree.
That’s a good bit of slinging! Ties to stop the strops moving in or out if the load was tipped towards one strop :)
To be fair, that’s experience and knowledge but it wasn’t me or our team. That was a supply only project to the Orkneys 😉
How did you find doing it yourself? We are still trying to get the windows sorted, very tough getting it right and deciding to self fit / not self fit. A few questions if you are up for them:
  1. Why did you go for self fit. EG When the VAT on the windows will be about the cost of the fit and so the whole package will be zero rated and supply only won't, getting it right will be down to the installers.
  2. How did you verify the sizing / fitting clearances?
  3. How did you find getting the cill details correct?
  4. I guess as you fitted then yourself you also did the air tightness work. (Our installers don't want anything to do with the air tightness work to the extent they do not want to fit the tapes to the frames before they fit them so they can go on the outer of the frame not take up frame space.) How did this go?
  5. How did you move the windows around the site to get them to the lifting points if working on your own?
I've just ordered my windows.
Cost is the reason for self installing. Period.
Sizing is done of the drawings. There is 10mm clearance all round on most windows. For the 5m wide slider ther is more clearance, especially on the height as the opening could sag.
Airtightness will be done according to the manufacturers recommendation, compriband etc...
Aluminium sill extensions in my case are about 50mm ,just to cover the stone sill below.
Moving windows... tractor , digger , dolly , sockets and manpower I expect.
Careful. you are assuming the openings have actually been made to the size on the drawings.  My builders came and measured the actual as built opening sizes before ordering the windows.
