Which multitool blade for brick and mortar sugery?
epsilonGreedy
I need to comp into a small section of masonry wall for a local repair, actually a few locations. Nothing more than 1ft across.
My options seem to be blades that look like a wide multitool plunge blade and the other option is a semi circular blade. Which multi tool blade should I choose?
In ascending order of harness I need to cut into and remove bits of the following:
  • Fibolite (clay bubbles) internal wall block.
  • Mortar.
  • Regular clay bricks.
  • Denser coursing concrete bricks.
Looking at these:
https://www.toolstation.com/smart-multi-cutter-mortar-buster-blade/p46597
https://www.amazon.co.uk/Bosch-Starlock-Carbide-Riff-Remover-Multi-Tools/dp/B009TGOMJ6
