PIR as a Showerlay plinth??
Hi all,
I'm working on the ensuite now and have seen this Marmox Plinth as a good option to build a shower tray up on top of the slab so I can get drainage underneath. (cant dig into the slab so have to go above it and out the wall for the drain.) The plinth is fixed to the slab with a flexible, cement based tile adhesive.
On top of that plinth I would then install a showerlay such as this... Marmox showerlay.
My question is: Could I substitute the plinth with some leftover 100mm Celotox PIR insulation? It seems like essentially the same thing. Is there any reason why this is a bad idea?
Thnks in advance.
Edited by connick159
