UFH design: local or national name
WWilts
Builder's plumber subbie said to be a heating engineer too. Price from builder (main contractor) excluded UFH design.
Options for design
1. Builder's plumber
2. Some renowned supplier
Which is likely to be more cost-effective?
(Not wishing to be penny wise pound foolish nor to over-spend)
PS I have also started playing with LoopCAD to try and understand a little about this. Not yet worked up the courage to have a go at the detailed design
9 minutes ago, WWilts said:
Considering known names
Wunda
NuHeat
or
the bigger retailers who also offer a design service
Hi @WWilts currently going through the process of obtaining quotes of this part of our build , based on what i have been quoted, the local firms are way more competitive  price wise than the national firms
Edited by Buzz
Do you mean for supply and fit or only supply …? I guess you’re talking the big names such as Nu-Heat etc who are usually 3-4 times price of the suppliers such as Wunda. I think they charge £50 like most for a loop cad plan but they are pretty good.
Had a go with LoopCAD.
Probably some obvious rookie errors there, grateful for advice.
If I can get the right end of the stick, then can discuss things intelligently with the professionals.
1. Peak capacity
2. Water temperatures
3. Surface temps
4. Circuit temps
Edited by WWilts
