Discharge of conditions
DragsterDriver
How bad is it to start below ground work before conditions have been discharged? I’ve been quoted 8-12 weeks by planning.
To discharge Condition 3 (Materials), 4 (Character), 5 (Drainage), 8 (Biodiversity improvements), and 10 (Highway Safety) of decision dated 17/12/2019 for Proposed replacement dwelling.
Your in the same position as we was and are again
Waiting for discharge of conditions Whilst summer rapidly disappears
Unfortunately your taking a chance if you do
Though it’s very unlikely you will receive a visit from planners Though highways may turn up
that’ll be fine, they can use the new entrance ?
it’s just another failing of the system really, would take half hour to check the conditions while I’m living in a static waiting for rain season...
I’ll crack on with field drains etc so it’s not a swamp which I reckon is preparing the plot- but what I really need is the piling contractor...
Keep the planner "warm" by saying how prices are escalating and you want to still deliver the dwelling to add to the local housing stock. Offer to be as helpful as possible, inviting any requests for clarification or information. You are Mr. Helpful.
Then 4 weeks after your submission of details do something similar.
6 weeks after your submission send a "Deemed Discharge" notice using the prescribed format. Confirm that you have not appealed.
Planner will have 2 weeks in which to respond failing which you will get "Deemed Discharge" automatically. Most planners will ensure that they respond before that happens. Make it easy for them to approve. Provide plenty of convincing info in your submission.
Has been known to work.
The standard 7 weeks 4 days I expect!
I  suppose there is a slight risk of problems with your vat reclaim if they were to investigate because they require the work to be legal. Unlikely though.
Make sure you have claimed the CIL exemption and got the paperwork done for that.
Yeah- I was very careful around the cil!
6 hours ago, DragsterDriver said:
I’m wondering what’s actually at risk
Your proposed details might be rejected, and something quite different required. (Most planners have bigger decisions to worry about, too busy to go into these details.) If you have spent money installing the rejected details, Enforcement might make you undo the work and follow the new details.
That is the worst case scenario. The more likely scenario will be that the planner spends a few mins (between big jobs) looking over your details. Approving them, with caveats where necessary. If they find something seriously objectionable they will let you know.
  • 1 month later...
