Marmox Thermoblock or Foamglas Perinsul
BenP
Any thoughts or preferences on the above.
I recognize the difference between the two - Foamglas Perinsul is stronger (throughout) but less thermal performance. Thermoblock performs better but achieves compressive strength via inserts within it.
It strikes me that the Foamglas has the benefit of acting just like a block so should be easier for the groundwork to adapt to? Most builders don't seem to be aware of the type of products or detail it's associated with!!
1 hour ago, Oz07 said:
How much of a difference do these make compared to a dry airated brickette?
About 80% less heat conduction relative to dry autoclaved aerated concrete
I wasn't aware of the exact figures so ta! :)
We're having a suspended beam and block floor due to ground conditions so it's the one weak point in the thermal envelope - especially as the roof and walls will be timber frame insulated between and over.
3 hours ago, BenP said:
Thanks - fewer bits of information and suppliers online but I'll get in touch.
Go direct to Sales@armadillonv.com
i was quoted in October last year
Armadillo ARMATHERMTM 500-160 Thermal Breaks
2000mm x 100mm x 50mm Blanks TB1
£20 per unit
Armadillo ARMATHERMTM 500-250 Thermal Breaks
2000mm x 100mm x 50mm Blanks TB2
£20 per unit
  • 2 years later...
Can I ask what you went with in the end and if you have any advice you can share from experience gained?  Asking myself the same question right now.  Cheers
