Joints in OSB sheathing
ThomasD
I am stick building 145mm panels for a 60msq workshop building.
My question is should the vertical joints in the OSB sheathing be:
1. Between the vertical 145mm studs (with 2mm expansion gap between boards)
2. Centered upon a vertical stud. (Theoretically, in terms of racking resistance, this option is obviously better but realistically it’s difficult to fasten with a nail gun the edges of the two sheets onto one stud)
option 1 is obviously a lot easier!
Thanks.
When I lined my warm loft with OSB I didn’t bother lining up on rafters, instead I joined panels with 100mm strip of OSB, bubble glued and screwed (to make it airtight), saved a lot of waste.
