Vijay Posted June 5, 2021 Share Posted June 5, 2021 I didn't even notice the waste pipe lol Link to comment Share on other sites More sharing options...
Nickfromwales Posted June 5, 2021 Share Posted June 5, 2021 29 minutes ago, Vijay said: I didn't even notice the waste pipe lol Less gin, more tonic ?? Link to comment Share on other sites More sharing options...
Vijay Posted June 5, 2021 Share Posted June 5, 2021 7 hours ago, Nickfromwales said: Less gin, more tonic ?? lol I'm T total (although I don't know how lol) 1 Link to comment Share on other sites More sharing options...
Water Posted June 6, 2021 Author Share Posted June 6, 2021 On 04/06/2021 at 17:13, Vijay said: Did you get a chance to measure what's been removed/left? yeah only managed to get down there today. It’s mostly 30 to 40mm with the a small section at 50mm. Link to comment Share on other sites More sharing options...
Vijay Posted June 6, 2021 Share Posted June 6, 2021 3 hours ago, Water said: yeah only managed to get down there today. It’s mostly 30 to 40mm with the a small section at 50mm. removed or what's left? Link to comment Share on other sites More sharing options...
Water Posted June 6, 2021 Author Share Posted June 6, 2021 (edited) Sorry Vijay removed, the whole section is about 2m long. Edited June 6, 2021 by Water Link to comment Share on other sites More sharing options...
john1 Posted Wednesday at 08:53 Share Posted Wednesday at 08:53 (edited) Hi, what a challenge! Plumbers seem to do whatever,... I have a similar question. A plumber cut a hole in the external wall to make space for a waste pipe. The cut is about 40mm deep, 400mm wide and ca. 100mm high. The wall is an old brick wall, that is ca. 360mm thick. Equally, my question is whether I should be worried about structural integrity? The cut is smaller than 1/6 of the thickness of the wall - however I also understand that such cuts are not commonly done anymore. One hope is, that because its underneath a window, not much weight is put on that part of the wall - but the weight sits more left and right of the window see sketch attached Edited Wednesday at 08:56 by john1 Link to comment Share on other sites More sharing options...
BotusBuild Posted Wednesday at 09:42 Share Posted Wednesday at 09:42 John - don't worry 40mm out of 360mm will make an insignificant difference. Link to comment Share on other sites More sharing options...
