Best way to cut crackle glaze tiles.
MikeSharp01
Anybody got any good ideas for cutting crackle glaze tiles without edge damage. Can't get better than attached with wet wheel. Left is cut and diamond polished bevel right is as cut with slight diamond bevel. Left shows too much base to be acceptable while right is too damaged without diamond polishing. Any thoughts?
18 hours ago, nod said:
I use these Fast cutting ultra thin
What machine are these for, angle grinder or a tile cutting machine? Also what is the lube if not water. I tries cutting with water but the muck gets in the crackles! (Not acceptable to customer - our daughter!)
