Which appliances need barrier above them??
I've got an oak block worktop from worktops express. About 40mm thick.
They advise a moisture barrier stuck to it's underside where you have a washing machine, oven or dishwasher. They talk vaguely about heat and moisture.
Is a barrier needed above a fridge with a small freezer compartment?
thanks
1 hour ago, ryder72 said:
I am not sure oiling it once will provide a lifetime barrier. Metallised foils are better as they are impermeable and deflect heat away as well.
 Agree - I was suggesting oil plus the barrier rather than just oil (probably wasn’t clear)
