Flat rate property tax of 0.48% to replace council tax and stamp duty.
According to the Sunday Times the Treasury is investigating scrapping stamp duty and council tax and replacing these with a simple annual tax of 0.48% of a property's value. I think this would be £ neutral for me.
One downside is that it undermines local democracy because voters can no longer punish a local council for reckless spending.
Wouldn’t get through parliament as it would crucify the London renters who pay £1,400 a year council tc in Shoreditch for a 2 bed flat worth £800k. They would see their bills jump by over 2.5 times, and if they go after the landlord then they will just add it to the rents.
Interesting one. Looks carefully pitched in value terms.
£2400 on a 500k property. Not too out of balance for normal houses in Outer London in CT terms. Would cost buyer there a few hundred a year and save approx 15k on the Stamp.
Would seriously impact those places like Westminster / Wandsworth where CT has traditionally been low, but would save more on the Stamp.
Impacts elsewhere less extreme.
Works for all of those.
Also works for the Red Wall and other areas as SD levels are very small for the vast majority. Also in such areas CT is higher, so it would play to "levelling up".
Peter is right that renting is the hard case. They could try keeping and increasing Stamp Surcharge. I wonder if coming London price adjustments may make a difference.
One issue is greater centralisation nationally, as  there may need to be inter-area adjustments.
F
It's not the big one though.
CGT relief on main dwelling needs to just go to undistort the market. That is worth £25bn a year and the benefit is heavily tilted to the better off and the rich areas.
As it is a tax on gain, all that happens is that the gain is a little smaller.
The tax reform is designed to shore up the red wall, a test case is the Chancellor's constituency in Richmond Yorkshire where most would be winners. During the brexit debates we learned that half of MPs secure additional responsibilities in government so plenty of incentive to keep the conservatives in power down south.
There is a drive towards simplifying tax but SDLT and Council Tax are both simple and easy to collect so I don't think there is any efficiency savings with the 0.48%.  It would mean a lot of time spent revaluing because the bands were quite simple and they would need to be accurate.
Next budget is the 3rd of March so not long to wait. Most probably there will be an obscure reference to a consultation exercise that will report in early 2022 by which time they won't risk overhauling such an emotive issue with the next general election 2 years away.
Back on topic.
The genesis of this idea seems to be in a piece on Conservative Home by Kevin Hollinrake MP, from the All Party Housing Group.
"In place of the administrative challenge of council tax, in which properties are taxed through a confusing and distorting system of bands and exemptions, the PPT would apply a single rate of tax – 0.48 per cent of property value – to all homes. Owners rather than tenants would be responsible for the tax, removing over 8.7 million households from property tax altogether and saving councils an annual £400 million in administrative costs.
To incentivise more efficient usage of existing property, a surcharge on second, empty and offshore-owned homes would be introduced, as well as on plots of land that received council planning permission yet have been left vacant by developers. The policy is revenue neutral – raising the same amount of money for the Treasury as the scrapped taxes currently do.
To maintain the important democratic link between local expenditure and local taxation, Fairer Share recommends that the 0.48 per cent rate should consist of two components. A fixed national rate (0.32 per cent) which would go to central government for redistribution and an initial floating local rate (0.16 per cent) which would go straight to the local authority and could subsequently be moved up or down by that authority. In this way local authorities retain flexibility over taxation and voters can still judge them on value for money.
And importantly, this approach includes the complete abolition of stamp duty land tax (SDLT) on owner-occupied residential property. "
https://www.conservativehome.com/platform/2020/09/kevin-hollinrake-conservatives-must-consider-a-proportional-property-tax.html
It is quite a long, interesting piece.
Looking at that, it seems to aim to solve the "granny in a £2 million house" problem, by reducing the transaction costs of leaving, and slightly increasing those of staying.
F
I think the logical time to do it would be either at the end of a short extension to the Stamp Duty holiday, or immediately. That would entirely lance the kind of chaos Nigel Lawson caused in 1988  when he gave 4 months warning of major change to close a huge loophole.
I have not got my head around whether likely house price fluctuations after COVID would make it easier or harder to implement.
Liability on rented property would make a big difference to me, as Council Tax tends to be around 20% ish of the rent. That would be punishing, and I am already well into 5 figures in Corona in adjustments, rent rise delays, and writeoffs helping tenants get through intact.
If adjustments are not too lumpy, I may really like this.
F
If adjustments are not too lumpy, I really like this.
Covid has sharply accelerated the move to remote working, now couple that with London rentals becoming untenable as per the @PeterW example and the result could be a big downsizing shift to the provinces.
This would be advantageous for those in crappy areas and bad for those in smart areas
Council tax amounts by band seem fairly similar throughout the country, so each band reflects a similar house.
The less well off areas would see savings of over 60% and the affluent area increases of the same amount.
I cannot see it being a vote winner in London and the Home Counties.  I also cannot see how it will be balanced - it looks like they will need to raise further tax elsewhere of increase the rate.
I am nervous of change.
When I bought my first house the RATES were £220 per YEAR.
Then it changed for the poll tax.  Great, everyone will pay not just the homeowner so it will be cheaper .  WRONG.
Then it changed for the council tax, back to a lower figure like the rates then?  WRONG
So if it changes again, which way do you think the cost will go?
I really can’t see anything as game-changing as this actually happening but this is a fairer direction to head in.
Better a land tax, for most folk the land value is the house value. Like a house in a garden...
For big land owners they have to pay more, don't pay the government take the land and sell it, but of course self builders of eco friendly homes get first dibs and a 10% discount, no chance of dodging the tax, can't hide land can ye
Edited by Tennentslager
By "crappy areas" do you mean all those places where more than half of your fellow country men live?
It is not meant to be, General Elections are won in marginal constituencies now referred to as the "red wall".
I hope you are right. I paid £90k in SDLT a couple of years ago, which added some 5 years to my mortgage. This change would quintuple my annual council tax as well as introduce a burden on me as a landlord.
I agree. Paying back the £400 billion of funny money quantitative easing created in the last 9 months out of thin air, is going to require tax reform of stupendous proportions. The people of this country have little perception how different their remaining life will be.
