12mm adhesive - what will it bed to?
NeilScotland
Hi all,
I have some 10mm tiles (1m x 1m) - so they are large. I believe i should use a 12mm adhesive base. Things are a bit tight - as the door level is about 20mm......
In any case, what would you expect a 12mm adhesive bed to go down to once the tile is placed? 8mm? (meaning my total circa 18mm).
I'm using a large format adhesive, lightweight I believe, COBA 140 (not sure if this brand in UK - I'm in Amsterdam).
Hope to hear, thanks.
Neil
5 minutes ago, nod said:
18 mil is to tight You will still have to back butter the tiles
Aha yea, i was planning on that too.
So..... any advice on what 12mm, 10mm etc would bed to - that would be welcome.
I know I shouldn't but I might have no choice but to go for shallower bed..... it is tight. Below is a pic of the floor and the door ledge.
thanks,
Neil
6 minutes ago, jfb said:
how flat is your floor?
When I place a 1500mm level around the room /floor. It's level everywhere.
There was a raised part at the door (the most important part!) but the builder came by today to level that off.
Another pic for reference. It's about 20sq m. New extension to the house.
1 hour ago, NeilScotland said:
A better pic explaining what you see here..... it's circa 22mm
The tiles will stay down fine on a shallow bed Tge problem you will have is laying them flat
We normally allow 18 mil for tiles of that size
If you are struggling it may be worth using a smaller tile
