Dwarf wall question
ChesterIOW
Hi, I'm hoping for some advice.
What problems might I encounter if I build a conservatory on top of an existing dwarf wall that is soaking wet and full of rainwater inside it's cavity?
Should I wait until spring when it's completely dry, or can I build upon it now? The dwarf wall consists of red brick on the outer, insulation in the centre (but it has a 2cm gap open to the weather all the way round) and thermal blocks on the inside.
Will I get damp problems or some other problem I have not thought about if I put the conservatory on top of it now, rather than wait for warmer dry weather?
Thanks.
1 hour ago, ProDave said:
Pictures to show context?
Is it only wet because it has been exposed and the rain has filled it up, or is it wet because it has no DPC and is wicking water from the ground?
Yes, it was built in August and has been left uncovered and exposed to weather since then.
