Concrete edge blocks - cement?
Hi All,
I'm about to lay a 15sq m patio with slabs /tiles.
The tiles are 90kg each (15 of them).
I'm edging with a pretty basic edging block (See image). They are 100 x 15 x 4
Should I cement these in place or just dig down the relevant depth and then support with the sand subbase I have?
thanks,
Neil
8 hours ago, NeilScotland said:
OK. clear, thanks.
Next question,.... what cement should i buy? ?
Any good quality flexi adhesive
We normally use Tilemaster
Less than a tenner a bag
Manufactured local to me
Hi Nod,
Thanks. are you referring to the tiles or the edgers?
I’m meaning which cement option should i use for the edgers.
thanks!
Unless you have access to a small mixer your best bet would be to get concrete delivered. If you get a fairly dry mix you can use it to form your base plus set the edgings.
You going to need to have your tile, adhesive bedding, concrete and then compacted hardcore. As for depths your looking at 150mm compacted hardcore, 100mm of concrete, 30mm adhesive. The slabs are 90kg so they are very very heavy so you can't skimp on the sub base or they will sink.
For hardcore your going to need 5t and concrete 1.7m3. That should be enough to form the base plus have enough to set to edgings and haunch the back. But this all depends on the actual size you finish with plus how level you can get the hardcore and then the concrete. With each step of this process you need to get more and more accurate. After you dig it out you could be 60mm out. After the hardcore maybe 30mm out. After the concrete 10mm out. You don't want to be starting to bed these tiles and find your 50mm out as due to the weight of these tiles it will be very difficult to take that out in the bedding of the adhesive.
