Best way to clean patio jointing (grass stains)
AdamD
We've made the mistake of not clearing the grass cuttings away properly lately (lazy!) and as such they've been blown onto the patio, got wet and subsequently stained some of the jointing (not much, luckily, but enough to be an eye sore). The jointing compound we used was pavetuf  (buff colour) https://www.pavetuf.co.uk/jointing-compound/ and I can't seem to shift the green grass stains which is really frustrating. Any ideas what solution/chemicals could do the job?
Worst case scenario I will just add a bit more compound over the top to cover it (I have half a tub left over) but don't really want to resort to this every time it needs a clean.
Advice appreciated!
24 minutes ago, nod said:
Algae-cide
You will need a dry 24 hours Dilute 20-1 and spray on with a plant sprayer The rain will do the rest 7 days later
Great, thanks. A dry 24 hours? Ha, may get it cleaned in the spring then!
https://www.amazon.co.uk/Algaecides/b?node=4364580031 - any of this? Says it is for spas but presumably the same chemicals.
On 01/11/2020 at 19:46, Dave Jones said:
Thanks.
Before reading your reply I went for 'Pro Kleen simply spray and walk away' but if it doesn't work I'll give the sodium hypochorite a go. It is very frustrating as across a 40sqm patio the jointing of only about 4-5sqm is affected. Looks horrible.
