GypWall metal studs
willbish
6 hours ago, nod said:
Ask away
My two questions are earlier in the thread.
1. My Wall height is 2750mm. Can I use a piece of 2”x3” under the u-track to raise it by 50mm and use 2700mm C studs?
2. I need to run 90mm MVHR ducting between rooms, can I make cuts in the deep u-track on the ceiling and bend over the metal to make these runs easier?
