Aerated block - cracking?
Moonshine
I am looking to use aerated blocks as the internal leaf of a fully filled external cavity masonry wall.
However I have heard that they can crack easily and also you have to dot and dab onto them.
How secure are screw fixings into them?
Has any one got any practical experience of using them in this way and issues they had?
Edited by Moonshine
I don't like them, they are basically made from a fines only "concrete" mousse, i.e. the slurry has heaps of air entrained into them. They are usually more expensive than ordinary blocks so unless weight was an issue I'd always just use block, they are not as strong, they are actually worse for the environment than ordinary blocks due to the high energy costs for preparing the materials for use in the "concrete". You also can't get a reliable structural fixing into them either as under high loads the bearing area tends to crush opening up the hole over time, perhaps something can be done with epoxy however the block is so wimpy you'd never trust anything of any importance on it.
you get a better U-value performance from them, which drew me to wanting to use them, though i may ditch them for a standard lightweight block for a 0.01 increase in U-value
37 minutes ago, Mr Punter said:
I prefer medium density aggregate blocks.  They are inexpensive, easy to fix to, easy to render / plaster.  Have you worked out the difference in heating costs with the aero ones?  I suspect insignificant.
I haven't but the wall u value goes from 0.17 to 0.18 and I am more concerned with the overall SAP score
It is important that the mortar mix is correct and not too strong or it can cause cracks.
There is a golden rule in the building industry that states ‘mortar should never be stronger than the material it is joining’.
Some good advice here:-
https://skill-builder.uk/aircrete-blocks
These Fischer Duopower wall plugs work well:-
https://www.screwfix.com/p/fischer-duopower-wall-plugs-6mm-100-pack/1030P?tc=KT1&ds_kid=92700048793290424&ds_rl=1249413&gclid=EAIaIQobChMI3oXXyb6R7AIV0-ntCh10cQq9EAQYASABEgIxmPD_BwE&gclsrc=aw.ds
4 hours ago, MAB said:
As do Fischer's UX range that expand into whatever shape is required to suit 'problem' materials. I struggled with the cheapest of cheap generic wall plugs for years until discovering these...
Edited by MJNewton
  • 5 months later...
Thought I would add to this thread.
I ve used 3.6kn aerated blocks on my internal leaf of my cavity walls and I have fine vertical cracks in lots of places, they are worse on the sw wall. Nothing showing on the external brickwork. Not impressed with them, but would not of achieved an acceptable U value on walls without them.
House is built on concrete raft so not due to settlement but thermal expansion or moisture content change. Planning to wet plaster, may put expanded metal mesh over the cracks first and dot and dab the sw wall.
Cannot believe my house has cracks before I have had chance to finish the dam thing!
8 minutes ago, Wagas said:
Are Fibolites aerated? I used them on a previous build and had one or two cracks but nothing major
No they are ultra lightweight aggregate blocks.
Good thermal values for them, may look to use them rather than besblock ultralites
  • 1 month later...
+1
Mortar was the same 5:1 for all walls. Only the wet blocks have cracked so far. I'm going to keep an eye on the rest to see if that stays the case.
I'm trying to move blocks indoors in rotating stacks to dry them before using them. It's only a matter of time before I forget to replenish a stack and have to use moist blocks.
I never used or will use aerated blocks, too many cracks, even slamming a door will cause them to crack, thermal movements, waekness points, under windows, above doors, beside lintels all common for cracking
in contrast, medium density blocks virtually no cracks. - ten years on too
Personally I’d use 1:1:6 (cement:hydrated lime:sand).
The lime should make the mortar a little more forgiving with those blocks.
Might be worth talking to your architect/engineer/bricklayer about introducing some movement joints too.
The longest wall is 4.4m. I wouldn't have expected to need a movement joint in that. I thought they were only required at >= 6m ?
I am the bricklayer :) There are some pictures of my finest amateur work in the thread here
You can see in the pictures there that some of the blocks are very wet, much darker than the dry blocks.
If it is the blocks shrinking as they dry would the lime cause the cracking to be in the perps and not the blocks?
I used lightweight aggregate blocks, avoid aerated. Aerated is one reason why the volume builders dot and dab -  to hide the cracks. Can you not widen the cavity to improve the uvalue if needed and add more insulation? Wet plaster best for air tightness and a nice solid finish, good to fix to. My brickie said he really doesn't like aerated, very high suction and mortar can dry before it's cured in summer. Cracking seems to be brittle nature of the blocks, they have standard compressive strength 3.6n 7n, etc,  but weak flexural strength.
I'm already above DPM all around and lower slab is in. Have to make the best of what I have.
With my very limited experience of them I concur. During the warmer months I find that I have to dampen the block surface I'm laying on before mortar gets near them.
