Extension- Last Stuff.
7 hours ago, zoothorn said:
If this isnt a warning not to buy this ashp.. i dont know what is, its fkn atrocious
yours may be for whatever reason BUT there are many of us here that have no problems with an ASHP, So don’t blame ASHP,s, blame your designer fir a system that’s not fit for purpose  (as I keep on saying).
My ASHP is ace !
10 minutes ago, SteamyTea said:
Going to answer a question (somewhere between pages 3 and 53) about the noise of the compressor.
Does it have flexible pipework fitted to it, or copper?
Copper can cause noise transmission.
remember it's a split, doesn't make things easier...
5 minutes ago, joe90 said:
Ha, whenever was this easier?
None of this is going to be easy, even if we know the right answer.
6 minutes ago, PeterW said:
copper as it is a split system not a monoblock so is running refrigerant lines.
Do all split systems do that, or do some pump coolant fluid to the outside unit.
And would you still need something to stop the vibration from the compressor anyway.  Worth a bit of investigation surely.
What unit is actually fitted, I can't be arsed to go and look.
Edited by SteamyTea
 Vaillant split Arotherm from memory
36 minutes ago, dpmiller said:
beetlejuice
Instead of saying candy man, candy man, candy man you say valiant man three times and they will appear look at your ashp setup, deep inhale of breath and say nah mate it's meant to sound like that.
you bad man.
  • 3 weeks later...
