Leaky wall
Pocster
This walls always been a pain .
It’s been supposedly fixed before ( cracks in External render filled )
This is the downstairs lounge wall . Bathroom directly above . Bathroom internal wall seems fine . No obvious leak in bathroom. No water marks on ceiling in lounge . Assume not a roof issue as half way down .  Nothing obvious outside , even checked in the rain .
Edited by pocster
8 minutes ago, Mr Punter said:
What is the wall construction?  If is is cavity, there should be a cavity tray / DPC above the window lintel sloping to the outside leaf with weep holes either end to let water drain out.
Presume it’s cavity
There’s a lip above the window external directing water away . I’ll grab a photo later
If you were to lift a tile or two you may find the underlying roofing felt that should direct into the gutter has perished/split/sunk. Eaves protectors might help.
Even a blocked downpipe/gutter can contribute to something like this.
2 hours ago, Mr Punter said:
Well spotted.  Get your ladder and up you go.  You may find one of those ladder stand off brackets will make it easier if you need to unclip a section.
I don’t do heights . So up builder goes .... ????
Standing on the edge of a big hole playing with a scaffold winch is still working at height.....possibly even more dangerous as you don't have to erect anything or climb for it to be a hazard.
G i r l
