Fin for glazed fixed panel
Taff
Just had an email from window supplier. Can any one explain in lay mans terms! Re the fin.
email says pic attached
Good morning Chris,
Reference the above, an internal fin reinforcement as below is required on the mullion of the large fixed frame (ref 20) due to the size and location. I’m highlighting this to you if you feel it is something your client will need to be aware of.
1 hour ago, Taff said:
So does this run the full height or is it just a piece on the top and bottom?
Email doesn't say if its a horizontal or vertical mullion. Better ask if not obvious. Probably full width or height accordingly.
Edited by Temp
18 minutes ago, PeterStarck said:
I may be wrong but I thought a mullion was vertical and a transom was horizontal.
Spot on.
Imo they are referring to the vertical white rectangle which is the reinforcing fin strengthening the million against bowing. Drawing is a horizontal section I believe.
Nice, sharp edge to fall onto and headbutt at 6mm wide! If it has to be there I'd be asking for a 48.5 x 52mm clip on or similar "cover" at no extra cost and finished to suit.
Or...some split pipe lagging! ?
Edited by Onoff
