Hi from Essex, going to attempt to build my own extension.
David H
Hi,
I am going to attempt building my own front extension. Doing as much of the work myself that I can,  including drawing plans for planning permission!
Probably have lots of questions but will hopefully help others if they are doing the same :)
Thanks
Welcome.
I did my own planning permission drawings - the hardest part was getting started.
What software are you considering using? (Assuming software - paper based is fine too)
Do you have a building background?
Edited by dangti6
