Under Counter Lighting - 6500k
Ferdinand
I am looking for some inexpensive LED striplights with a colour temperature of about 6000k-6500k. That is roughly "daylight".
They will need to be linkable, and plug into the mains - so 240V or maybe a transformer. The product area may be shop display lights or under counterd lights.
My application is as growlights for microveg, as I continue to experiment.
I picked up the idea from an American site who recommend these:
https://www.amazon.com/dp/B07F2WMCP2/
I need slightly shorter ones 30-70cm long, as I am.
I already have some designed-as-growlights LED grid things, but I want to try these too.
Any ideas? Thanks
Ferdinand
26 minutes ago, ryder72 said:
Daylight is generally referred to the 4000k temperature range. 6000k is cool white.
I don't think that is correct:
Quote
Colour temperature is measured in Kelvins (K), and typically ranges from 2000K-6500K. The lower the number, the warmer the light. A typical warm white light bulb for use in living rooms and bedrooms would have a colour temperature between 2700K-3200K. Cool white bulbs are anywhere upwards of 4000K. At the far end of the scale, ‘daylight’ bulbs have a colour temperature of 6500K and are supposed to replicate the tone of light that the sun emits during the day. These would look very blue in a typical living room.
https://www.simplyled.co.uk/info/colour-temperatures/
I have found that when you start to go into the 5000 to 6000k range the white is very much too blue for me.
i like 3000 to 3500k in bedrooms and living rooms
4000 to 4500k in bathrooms and kitchens
Thanks for the comment. I tend to agree.
But this is for my green vegetables ?, such as watercress and dill weed.
4000k would be for flowers, and I can't eat so many of those.
Edited by Ferdinand
