Insulation on Beam and Block
NewToAllOfThis
We are have Beam and Block on A steel Beam and a timber frame building. The Frame provider has recommended blocks of 140mm sat on 10mm of mortar creating 150mm height. Then using 90mm of insulation and 60mm of screed.
We are not having underfloor heating, is this a sensible buildup of insulation and screed?
Are 140mm blocks available or would they need to be cut to size.
Looking for suggestions and information as to what others have done
3 minutes ago, Russell griffiths said:
I wouldn’t think 90mm of insulation even gets to building regs does it.
Probably above the minimum threshold but will need to make up elsewhere and floor insulation is simple to fit, just chuck it down.  120mm Celotex would work.
