Awkward Shower Shape
22 minutes ago, PeterW said:
Square the corner off, put the toilet on the squared off wall (could use a back to wall frame) and then put the shower where the WC should be and move the basin left ...
Best idea ?
That V shaped internal corner is going to be a really useless space.
I would +1 squaring off the awkward angle. Don't go in too deep when squaring it off - and you will have a massive amount of in-shower storage recesses!! All those bottles, and bits and bobs you always need in the wet area! You can even put plants in it! I love stuffing in shelving space wherever I can find it.
Oh I never thought of that - in shower storage recesses.....
Excuse the crude drawing but would something like this work? Kind of a walk in one if the corner was squared off. I imagine it would need to be 700-800 so would lose a bit of the space.
May have to change the entrance door opening side.
Edited by canalsiderenovation
5 minutes ago, Ferdinand said:
Square it off and put a triangular cupboard or shelves in the office or hall.
Its been built already, we have foundations and part built walls ? I'm stupid, the angle never really occured to me before looking from the plans.....
Could you move door D4 to the right so it opens towards the window? That'd free up a square corner in the bathroom for a decent sized shower.
I'd still square off that V though.
With hindsight I might have had the wc on my squared off corner and had a walk in shower in the adjacent corridor through the old doorway!
20180504_184620
P1210068
20190626_205015
Edited by Onoff
You can either form them yourself like I did:
20180604_180526
20180611_192838
IMG_20180828_242257343
IMG-20190111-WA0010
Or buy them ready made like @pocster has just done.
(I was limited on depth).
To minimise any moving of walls/ doors etc, and still keep a tray (if you don't want tiles to a fall as recommended above), then like this. Linear drain in the tray can still be applied against the top wall. Then it's up to you how you screen it off with shower screens, can be creative here to make any shape.
Edited by Bored Shopper
20180604_180526
20180611_192838
IMG-20190111-WA0010
Yes . They are expensive for what they are but takes 5 mins to install
It's for a second ensuite for the parents/Airbnb (we have our own) so I don't really want to start moving walls etc so armed with some newspaper I've been playing around with the layout.
Option one @Bored Shopper your suggestion.
This is based on 800*800 tray. Bit worried about the door on a tray and cleaning access. Not sure.
The other option seems to be as per my drawing and have a walk in shower and tray. Newspaper is based on tray of 1400*800. We could then have the entrance door opening the other side but don't think this is necessarily needed. From squaring it off to the entrance door wall the measurement of the wall is 2.9 metres.
13 hours ago, canalsiderenovation said:
It's the only real logical place but don't really want tiles but the tray shape on the plans doesn't exist!
Not quite right but would it be possible to somehow use an offset pentagonal shower tray.
So square it off and then something like this?
https://victoriaplum.com/browse/quadrant-shower-enclosures?csi=PFH98PRP&ds_kid=92700055266126519&gclsrc=aw.ds&&gclid=EAIaIQobChMIrOTyveTH6gIVuIBQBh3xFwbBEAQYAiABEgIQe_D_BwE
Where is the drain through the floor ..?? Or under the floor ..??
That will dictate where the waste goes - can’t see it on the pictures.
For me, I would go 1400/1500 x 800/900 and not worry about the door anyway - an 800 door would still leave a swing of 600 before the end of any glass frames (and a nice space behind the door for the towel rails)
