Outdoor BulkHead Light - Confused.Com
Barney12
Hi All
Really hoping for some collective advice! Like a fool I offered to look at a friends outside light as it (and I quote) "doesn't work". So of course the first thing I want to check is the bulb.
But..........I can't even work out how to get the cover off :(:(
I would have thought it unscrewed but it just spins round (in either direction).
I don't want to rip it off and break it!
any pearls of wisdom out there?
Pictures of said offending light:
Look carefully where the opal difuser joins the back plastic back. There will be a slot somewhere, usually at least two, to insert a flat screwdriver and turn to pop the front off.
Put a low energy lamp in. If it's got a filament lamp, chances are the wire is overheated and brittle now.
