Joiner made front door....will it be airtight?
Stephen Aitch
We are trying to do our best to create a pretty airtight house....
Our Architect has suggested a joiner made front door.  Will this be a huge source of air leakage?
We are installing MVHR and ASHP and it will kill performance if the door lets wind through.
Our current double glazed french patio doors let a gale blow through on windy days....
In a low energy house, the front (and all) doors need to be both airtight and thermally efficient - i.e. low u value & no cold bridges (so a solid timber door is not a good idea).
When closed, it needs to be secured against the frame to ensure the seals engage - multipoint locking is good for this.
I'd be surprised if a joiner could make a door to meet that criteria, risk is that over time a timber door may shrink and airtightness deteriorate.
We have a passive standard door from RK - foam core, aluminium structure, double seals etc - not cheap but we were aiming for a certain aesthetic.
I would have preferred to use an oak front door to match our oak canopy
Ive a friend with a workshop that would have made one for the price of the timber But conceded it wouldn’t be airtight and less so over time
Sk I fitted a composite door
I have had a joiner make our front door. It's not yet installed so I can't comment on how it performs just yet.
The joiner was responsive to the challenge of making something airtight and thermally efficient. I visited a few showrooms to take photos of the seal details and found tech drawings online. I think the door will perform very well during the airtightness test.
With regard to thermal performance I think it will be a slight weak spot, although we used a triple glazed sealed unit and 50mm PIR sandwhich filling there are areas where there is solid timber.
My front door (and frame) was made by the same joiners that made all my windows and bifolds, all in oak, I do have a closed porch to act as an airlock and it faces North. It fits tightly with multi point locking and is a  very good fit.i would disagree that a GOOD joiner could not make a  door like mine (it’s also foam cored).
Edited by joe90
Ok, I concede the point - a good joiner could do it but you will need to be be clear on the requirements.
This is one my friend made for me at our last house Cost me £300 plus the glass It sealed up pretty well
But like Joe mine was under cover
While we have a large oak canopy on our new house The front door is open to the elements and would be likely to sell or contract
One advantage with a timber frame is if the seals become damaged or crack they are very easily replaced Unlike UPVC
  • 1 month later...
On 27/06/2020 at 19:24, dpmiller said:
you said
" One advantage with a timber frame is if the seals become damaged or crack they are very easily replaced Unlike UPVC  "
Yep simple to pick out
UPVC are a nightmare to sort out
