Shower valve confusion
Hello. Please could you help me understand concealed shower valves.
I'm looking for one that will run an overhead rose and a small hand shower.
I've found this that I like
https://www.victorianplumbing.co.uk/hudson-reed-round-triple-concealed-thermostatic-shower-valve-with-diverter-rndtr03
When I read the information about it, I think the middle knob sets the temperature, and the 2 other knobs are one for each of 2 outlets.
But, it says it diverts to a third outlet.
Can anyone explain please?
That seems expensive for a start!
Similar to the Reign model I and a few others on here have. Still Hudson Reed.
Top control does the rainfall head flow
Middle sets temperature
Bottom does the handset flow
You can have both going at once.
20190626_205015
20190306_201231
Good price here:
https://www.qssupplies.co.uk/bathroom-furniture-shower-taps/57864.htm
Edited by Onoff
Thanks for the heads up on the price, I'll have a good scout around before buying.
It's thanks to BuildHub numbers that I'm focusing on Hudson Reed, I just prefer the completely round knobs to the ones you guys have.
Interesting the link you post gives an option of with diverter or without. So it seems I need one without, though I wonder if I got one with diverter, how would the unit be different, and could it function with just 2 outlets in use?
Edited by Jenni
  • 5 months later...
Hello.
Efforts are generally focused elsewhere, but I'm still mulling over shower valve options so I'm back again with another question.
A valve I Iike says "Hot water temperature 55 to 85 Degrees", and in the manual says -
Does this mean it's not suitable for use with my ASHP hot water system, where the tank will generally be at 45-50c?
(this one - https://www.victorianplumbing.co.uk/cruze-twin-modern-round-push-button-shower-valve-with-2-outlets?campaign=googlebase&gclid=Cj0KCQiAtqL-BRC0ARIsAF4K3WHWaUvYdYOK3-tAzM3bAkuwrTntu6RqCSAOVy4wduDyWU8hJr0EsssaAjibEALw_wcB&gclsrc=aw.ds)
Thank you Peter.
Are there any concealed valves (that you're aware of) that will work at lower input temperatures?
I will have an immersion, but would prefer not to be tied to using it all the time.
