Timber gazebo
Do two runs to the down-pipe, each collecting 2 sides of runoff so the duty is shared. Same cost, same effort.
Just have an inch fall from the highest points to the outlet at the down-pipe, so half inch fall on each run x2. Will give equal height where the two capped off ends meet so will still look uniform.
So, almost finished the felt tiles (just need to get a final bit of trim for the apex) and got the gutter on.D2DFDFA7-4E3D-4B15-809C-578BEA532221.thumb.jpeg.86026d79b20b6f6a4af6a152e961e208.jpeglooks nice but today it rained and good news is the roof does not leak but sumfink is up with the gutter
Profile of how it’s fitted
F48F33DE-0CE3-4930-A62D-A7BB30758F59.thumb.jpeg.efd2f61c5bb9592aae6637c4929ab373.jpegThe drips on the board the gutter is fixed to is the problem...
97A00A82-08AD-4F69-9BB9-BCF9B1C592A9.jpeg.d374ed181d884d56f5a14dbb7c0020b4.jpegSome water (most) is following the blue line but some is following the green line and dripping like fcuk
Very little overhang into the gutter, plus shallow angle must be allowing water to hug the surface and come back underneath.
If possible bend the end of the felt downwards so the droplets have to fall off the end
The felt tiles are prone to strong winds so followed the MI’s and put a good bead of adhesive on the bottom edge so no chance of sliding a trim up there.
But ordered a couple of rolls of 50mm flash band tape and although footery I can stick this to the underside of the tiles and down onto the inner face of the gutter!
Ill report back once it’s dry enough, Scottish weather forecast tonight was next dry day sometime after the weekend, ffs it’s August, rain all week
