Help me find a shower hose outlet fitting
ProDave
Fitting the en-suite bathroom now.  Had a slight problem with one sheet of multipanel that despite being templated needed a bit of adjustment.  The result of that is the hole for the shower outlet had to be enlarged slightly.  So now the hose outlet fitting I have does not quite cover the hole.  so I need a larger one.
This is like the one I have.  The flange that touches the wall is 45mm diameter  https://www.ebay.co.uk/itm/Keenware-KSA-003-Brass-Shower-Wall-Elbow-Outlet-Round/153689371778?_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D225114%26meid%3D16e9edb5c6bf458a8cec18299a196493%26pid%3D100005%26rk%3D2%26rkt%3D12%26mehot%3Dpf%26sd%3D114199202223%26itm%3D153689371778%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv5PairwiseWebWithBBEV1Filter&_trksid=p2047675.c100005.m1851
I have found this one that would do, it's 60mm diameter.  BUT it's plastic.  I really want a proper sold brass one.  https://www.ebay.co.uk/itm/Shower-Outlet-Supply-Elbow-75-x-60-x-35mm-Chrome-60mm/171729719523?hash=item27fbe390e3:g:KakAAOSwEeFVD8y7
I have also found this one  https://www.ebay.co.uk/itm/184167866578
That does not state the size.  I have messaged the seller and waiting for an answer from him.
In the mean time any other ideas?  I think I need at least 55mm diameter, 60 would be more comfortable and I really want solid brass not plastic.
50 minutes ago, Temp said:
Dimensions are about right..
https://www.amazon.co.uk/gp/aw/d/B07Z67Y9MG/ref=sspa_mw_detail_1?ie=UTF8&psc=1
Says brass but is it all brass or part plastic? Ask?
A big thank you.  That looks just like the one I have only the flange part (which is a separate part) is a larger diameter and will cover my bodged hole.  Just off to order it.
EDIT: only after ordering it and looking at the expected delivery date, do I find it's coming from China.  Amazon don't seem to make that as clear as Ebay.
