Looking for ideas for cavity closer for my wonk
Digmixfill
My new internal walls are going up fairly straight, which means the cavity size in some places varies quite a bit against my wonky outer skin.
There are a few places where the cavity is > 165mm  wide.  Any suggestions for cavity closing my wonk?
Edited by Digmixfill
Thanks for the suggestions. Food for though with more than one option.
3 hours ago, Russell griffiths said:
Very rigid rockwool, with a dpc stuck to one side.
A DIY Rockclose type of thing?
3 hours ago, PeterW said:
Standard cavity closers bonded in with low expansion foam
Are standard closers meant to be fastened to the brickwork? There will one or two places where a 150mm closer probably wont overlap the brickwork on both sides.
2 hours ago, tonyshouse said:
Cut sheet insulation into the open cavity , I closed off with plasterboard fully bonded to reveal then wet plastered the walls
http://tonyshouse.readinguk.org/274-2/
Are building control ok with this approach? I thought they expected some kind of fire retardation in the closer?
What are your inner / outer skins ..?
The PolyPipe closers have a 250mm plastic liner with removable foam sections to reduce down the cavity.
Inner is 100mm celcon. Outer is 235-240mm clay brick.
Polypipe WCF200 would do the job nicely, but my they're pricey ?
How much are you being quoted..?? Think I paid about £6/ex-VAT
Quick search found this http://www.discount-trade-supplies.com/shop/product/1925-Multi-Width-Insulated-Cavity-Closer/
The first price I came across for the WCF200 was £54 inc VAT - no indication of multiples or a pack, so i'm taking that as each. Apparently that's with 18% off rrp.
