Cleaning render
AliG
Birds have built a nest in our guttering and the render is filthy.
I had a go with the jet wash, which I know isn’t recommended, but usually gets stuff off.
It’s not working well on this. Also I need a taller ladder out to get to the top.
Reading on line there are specialist render cleaning companies and they say you need to use hot water and detergent.
I also found CT1 recommending Multisolve which is for cleaning adhesive to clean bird droppings.
Would I be crazy to fill a bucket with warm water and Flash and brush that on to see how it goes?
Edited by AliG
  • 5 months later...
In case anyone has a similar issue.
I hired a one man tower and set it up.
Scrubbed off the dirt with water and Fairy Liquid. You could still see the stains.
I sprayed it with Cillit Bang Black Mould Remover, left it for a few minutes and rinsed it off. Worked a treat. You can only very faintly see where the stain was, if I had left it on longer it would have been better, but I wasn't really enjoying being up the tower.
I now plan to use this on my garden walls where I have some areas of staining.
