Bathroom Fan replacement
Hi,
I'm planning to replace a Bathroom fan that is tied into the light switch with a Vent Axia VASF100HTV. I want to break it away from the light switch as I use a different set of lights 99% of the time. The installation diagram shows something between the switched live and neutral. I'll get a separate pull cord and fan isolator for the project but what is the purpose of the arrowed item? Thanks!
