Powerfloat Finish
LA3222
14 hours ago, JOE187 said:
brilliant thanks.
13 hours ago, Russell griffiths said:
Concrete will push water
get a wet vacuum cleaner, pump in concrete to the to the edge beam first and it will push the water around, suck out from last corner.
Scared to death of putting it in the ring beam first as per the other horror story where it all floated up! but a good method nontheless.
You don’t put it in, in one constant area, you need to move the pump hose at a good walking pace, placing the heavy concrete on all the areas.
So walk all around the ring beam filling up 100mm splash a barrow full on all flat sheets to keep them weighted down, you should go through the first truck of concrete in under half an hour.
If you are still unhappy just walk haphazardly around giving everything a 50mm covering.
Or why are you not putting another thin sheet of polythene down like you would for flowing screed.
For £150 of polythene I think it’s a no brainier.
  • 1 year later...
On 26/01/2021 at 10:18, mvincentd said:
Power floating even dead smooth won't entirely prevent dust coming off it...and dead smooth will make it harder to use a penetrating sealer (impossible if its also waterproof concrete), and a topical sealer will struggle to bond well....you'll need a specialist powerfloat sealer like Watco (https://www.watco.co.uk/products/watco-powerfloat-sealer).
Hi we are planning to have a power floated slab as our finished floor surface. I was thinking of applying Sikafloor ProSeal W - https://www.rawlinspaints.com/home/floor-paints/floor-sealers/1542-sikafloor-proseal-w.html?gclid=CjwKCAiAmuKbBhA2EiwAxQnt72lVa5Y-KR9dS83fdH9pL4WPUkN7B6KcZVjnsokdhLAhIF5tM2oVfxoCrF4QAvD_BwE
- after the powerfloat. How does the Sika product compare to this Watco sealer? thanks
