Powerfloat Finish
LA3222
How 'polished' should the slab be? Contractor is saying that it doesn't want to be too polished if tiling etc direct onto it?
I know that powerfloated slabs are difficult to bond to, but wheres the happy medium?
Edited by LA3222
1 minute ago, Mr Punter said:
Bull floated should be fine if you are tiling.
Rog ?they're out there now doing it and asking me if I'm happy?‍♂️
In my mind, the powerfloat was to iron out any bumps/uneven spots and to 'seal' it as such so dont get concrete dust coming off it!
14 minutes ago, vivienz said:
I had a good finish on my slab but I wouldn't have described it as dust free.
Same here.  I sealed our slab with diluted PVA, made it a great deal easier to sweep up dust, shavings etc.  Ours was powerfloated pretty much dead flat, and we have a mix of large format travertine tiles and bonded bamboo flooring (the latter stuck down with Sikabond 95) fixed directly to it.
If you are tiling it needs to be flat, so check it with a long level and some packers to see.  If you can easily slide a 5mm packer under in lots of places then it may need a fair bit of levelling compound.  Localised bits the tiler will get over.
It doesn’t make any difference for tiles
Though most commercial jobs that I price are including Ditra matting in the spec
The tiler that laid our 600mm x 400mm honed and filled travertine spent half an hour going around with his laser level to try and find the highest spot, apparently so he could work from there to get the level right.  He gave up after faffing around for that time, saying that he couldn't find the highest spot as the whole slab was within a couple of mm of being dead flat.  Made his life a lot easier, apparently, although it did mean that I had loads of tile adhesive left over, as he ended up using a lot less than he though he'd need.
1 hour ago, Oz07 said:
Finished pics today @LA3222
It's all covered over at the minute, they didn't finish till late evening when it started getting dark and out of concern for frost I covered it asap with frost blankets while had a bit of light left (it was a rubbish job - windy as hell and I had to deploy the head torch!)  Weather here is it's own beast and seems contrary to general forecasts?‍♂️
Its crap weather for next couple of days so I'm just gonna leave it covered for now, will pull it all off when the sun comes out next week and get some photos up.  Seemed ok to me but then trying to judge things like 'level' is nigh on impossible with the naked eye.
  • 9 months later...
25 minutes ago, LA3222 said:
Yeah slab was fine bud. If I remember rightly it was C28/35 mix. How are you getting on?
We have cut level now, so stoning up today then surveyor tomorrow to set out profile boards and then cut drainage and ducts in. Hoping to have the profiles down and all sorted by early next week. You'll likely see a flurry of questions come your way. ?
Did you line up the profiles get it all right then take them out 1 by 1 and spray the soudal low extension foam between all mating faces?
Get the corners where they need to be and then fill in from there. I assume you've got low expansion foam, I tended to use as little foam as possible, just enough to securely grab the adjacent blocks. The pins are crap.
My biggest issue was the lengths of my long walls are nearly 20m that was alot of blocks. If the gap between blocks is 1 or 2mm by the time you get to the end you're out by 20 to 30mm. I had to fill in from the corners and then trim a block to suit the last gap as you go.
I glued as I went. If you make a mistake its easy enough to re seperate the blocks by cutting through the join with an insulation saw.
Power floating even dead smooth won't entirely prevent dust coming off it...and dead smooth will make it harder to use a penetrating sealer (impossible if its also waterproof concrete), and a topical sealer will struggle to bond well....you'll need a specialist powerfloat sealer like Watco (https://www.watco.co.uk/products/watco-powerfloat-sealer).  I'd think the advice with a dead smooth powerfloat would be to scarify it to get a bond to it so unless you want the powerfloat as your finished floor why aim for dead smooth.
Regarding dead flat, I believe on-the-day conditions will always be a factor in what can be achieved powerfloating, particularly for large areas.  One observation from mine; pump out any significant rainfall thats trapped in there....1cm deep water across the area will be much deeper when pushed by the concrete all up to the last corner where the last concrete gets dumped, so that concrete's consistency will be significantly affected and its readiness time for power floating.
Powerfloating doesn't really redistribute significant amounts of concrete as it can only start once the concrete is hard enough, so if it hasnt already been tamped and levelled well powerfloating won't then solve levelling issues.
I'm no expert, especially re' tiling but i'd think if anything it's better to put tiling adhesive onto a bull floated surface than a smooth powerfloat.
(I repeat, i'm no expert)
Thanks @LA3222 I keep looking to buy a trade pack (as per previosu advice) of the soudal low expansion foam but just cant seem to find it quickly on a google search - even struggling to see just soudal low expansion foam, lots of other types from them but not that, albeit it mentions it specifically on there website.
My walls are also 20m long (I only have 6m width on main house) so good info at this stage! Need to add an insulation saw to my list!
this is helpful for sure, as dead flat is my aim, not so bothered about dead smooth as it's not the finished floor. The water is a good wee bit of info - I'll make sure it is as dry as can be!
