MVHR ducting planning
Just doing some planning before I get a company to do a proper design
does every extract point have to have have its own dedicated duct, or can two or more extract points run back to one duct and  connect with a sort of Y junction.
I have one area of ceiling that i that I would like to limit the amount of ducts in it, but this area then opens out into two separate rooms that would both have extract points in.
Extracts usually have two ducts to cope with the flow and minimise noise. You might get away with three ducts onto two plenums , depend on the room use, size and expected flow rate
Could you run a larger duct past the obstruction then have a separate manifold to serve those two rooms?
I wonder if the concern about a y-junction connecting plenums for two rooms is the risk of cross noise transmission from room-to-room. And secondarily I wonder if it could make balancing the system more difficult if those two rooms were of markedly different size.
