Delta board
Pocster
So , I’ve got this for bathroom and ensuite walls . First question - is there a side that faces in I.e tiled on ? - or does it not matter ??
Seems quite flimsy (12mn I think ) . Whilst I’m sure it does the job is it better or advised to marine ply the walls then attached the delta board ???
7 minutes ago, nod said:
Delta fine
no need for ply unless you are hanging something heavy
Hardly anyone uses marine now
Writing facing out
Cheers !
Does it compress ?
What I mean is if I hang a heavy wall unit ( it’s fixing go straight into stud ) - the unit is against tiles and delta underneath - will the delta warp / bend ?
Edited by pocster
Since the board apparently has a BBA Agrément Certificate, that should have the details.
I'm currently looking for a similar product so just tried looking it up and can't find one, and the link from their own web site is dead (at the foot of this page) which is curious...
1 hour ago, pocster said:
Cheers !
Does it compress ?
I would put a timber patress behind where you intend to hang anything Though Delta is pretty robust
