Floor insulation
Adam E
I Have concrete slab seems very level but I have put down the membrane and 150mm insulation boards
a few boards have a slight rocking no-more than 5-6mm Its a twist in the insulation board as if I swap the board problem solved but I can’t return the boards
I am putting down castellated panels for ufh and a dry screed mix, Should I be concerned about the uneven boards  ? and if so what’s the best way to fix the problem.
Cut the board across the centre of where it rocks.
I had this, where an existing floor met a newer floor - so I the jointed the boards at that point.
The screed installer told me not to worry as I had a couple of boards that still rocked a couple of mm, he said the weight of the screed will hold them down.
