To nog or not to nog...
gwebstech
Hi all
Ive just laid some 22mm p5 grade chipboard over timber joists, 400mm centres, glued and screwed. Im reading conflicting info about whether i need to nog where the board edges are not on a joist?
ive been told that if id cut every board to fit on a joist that would have been ideal, sounds obvious now but it my first time and ive dropped a clanger not doing that : (
as far as i can see NHBC standards say all short edges should be nogged
Anyone had direct experience of this?
thanks
Can unsupported joins be a cause for eventual squeeking/creeking? I am sure that's what happened above our lounge as, with the ceiling down, that appears to be the case in a couple of places. I haven't retrofitted some noggins yet but I am expecting (hoping) they will cure it once both boards are screwed down to it.
Not if everything is glued together and that includes the boards to the joists.
I always land short ends on joints. Lmow another chippy who was made to go and not underneath with some h section shape nogs by labc warranty. Learn from others mistakes. Probably nessecary and probably be fine but not hard to do
